Toggles the display of the hyperlink cursor, shortcut menu, and tooltips.
command bar: hyperlinkoptions
transparent: 'hyperlinkoptions
: hyperlinkoptions
Display hyperlink cursor and shortcut menu? [Yes/No] <Yes>: (Type Y or N.)
Display hyperlink tooltips? [Yes/No] <Yes>: (Type Y or N.)
Toggles the display of the "hyperlink" icon and the Hyperlink submenu on shortcut menus:
When the cursor passes over entities with hyperlinks, the "world" icon is displayed. When you right-click a selected entity that contains hyperlinks, the Hyperlink item is added to the menu.
Toggles the display of the hyperlink tooltip:
The text of the tooltip is specified by the Hyperlink command's Hyperlink Description option.
Hyperlink Cursor |
Opens the location specified by the URL. If a location on the Internet, BricsCAD opens the page in the default Web browser. If a file, BricsCAD opens the file in the associated application. This option executes the URL command. See URL command. |
Copies the URL to the Clipboard; the URL can be pasted into the drawing or other documents with the Ctrl+V shortcut. See PasteClip command. |
Opens the Edit Hyperlink dialog box for editing the URL, description, and other parameters. See Hyperlink command. |
-Hyperlink - attaches hyperlinks through the command bar.
Hyperlink - attaches hyperlinks through a dialog box.
Settings - sets options for hyperlinks in the Files section of the Settings dialog box.
Browser and Url - open the default Web browser.
OnWeb - opens the Bricsys home page in your computer's default Web browser.
Mail - attaches the current drawing to a message in the default email client.
© Menhirs NV. All rights reserved. |
