Imports page setup definitions from another drawing through a dialog box.
command bar: psetupin
: psetupin
Displays a File dialog.
(Select the drawing you want to import page setups from.)
Displays a dialog:
(Select one or more page setups in the list. Press and hold the Ctrl key to select multiple page setups, then press the OK key to import the selection into the current drawing.)
No options.
-PsetupIn - imports page setup definitions from another drawing through the command bar.
PageSetup - creates and edits page setups for plotting drawings in the Drawing Explorer.
Layout - creates, copies, renames, and deletes layouts.
