VSlide
Displays images saved as SLD or WMF files (short for "view slide").
WMF files are not supported on the Linux platform.
command bar:  vslide
aliases:  vs, vsnapshot
menu bar:  Tools | View Snapshot
toolbar:  Tools |
: vslide
Choose a file, and then click Open.
To remove the slide from the viewport, use the Redraw command.
File name
Specifies the name of the slide file.
Files of type
Selects the file type of the slide file:
  • Slide File (*.sld) is the proprietary graphics format used by AutoCAD for slides.
  • Enhanced Metafile (*.emf) is the enhanced WMF format.
  • Windows Metafile (*.wmf) is the hybrid raster-vector format developed by Microsoft.
Open
Displays the slide in the current viewport. Use the Redraw command to remove the slide.
MSlide - saves drawings in SLD, EMF, and WMF formats.
Redraw - removes the slide from the viewport.
