Activate method example
Sub Example_ActivateMethod()
    ' This example creates two new drawings adds them to the Documents collection
    ' it then steps through the Documents collection and activates each drawing in turn.
    Dim dwg1 As AcadDocument: Set dwg1 = ThisDrawing.Application.Documents.Add("")
    Dim dwg2 As AcadDocument: Set dwg2 = ThisDrawing.Application.Documents.Add("")
    Dim theDwg As AcadDocument
    For Each theDwg In ThisDrawing.Application.Documents
        theDwg.Activate
        MsgBox "Drawing " & theDwg.Name & " is active."
    Next theDwg
End Sub
