GetXData and SetXData method example
Sub GetXData_Example()
Const APP_NAME As String = "TEST_APP"
Dim anObj As Object
Dim pt(0 To 2) As Double
ThisDrawing.Utility.GetEntity anObj, pt, "Select an entity: "
Dim xdataType As Variant
Dim xdataValue As Variant
Dim appName As String
Dim sBuf As String
anObj.GetXData APP_NAME, xdataType, xdataValue
Dim lbnd As Integer, ubnd As Integer
Dim i As Integer
If (vbEmpty <> VarType(xdataType)) Then
lbnd = LBound(xdataType)
ubnd = UBound(xdataType)
sBuf = "Xdata for app " & APP_NAME
For i = lbnd To ubnd
If 1010 = xdataType(i) Or 1011 = xdataType(i) Or 1012 = xdataType(i) Or 1013 = xdataType(i) Then
Dim ptX As Variant
ptX = xdataValue(i)
sBuf = sBuf & vbCrLf & "XData Type: " & xdataType(i) & " Xdata Value: " & ptX(0) & "," & ptX(1) & "," & ptX(2)
Else
sBuf = sBuf & vbCrLf & "XData Type: " & xdataType(i) & " Xdata Value: " & xdataValue(i)
End If
Next i
Else
sBuf = "No XData for application " & APP_NAME
End If
MsgBox sBuf
Set anObj = Nothing
End Sub
Sub SetXData_Example()
Dim anObj As Object
If (vbEmpty = VarType(xdataType)) Then
Dim tmp(0 To 0) As Integer
xdataType = tmp
ReDim xdataValue(0 To 0)
xdataType(0) = 1001
xdataValue(0) = APP_NAME
End If
ReDim Preserve xdataType(LBound(xdataType) To UBound(xdataType) + 1)
ReDim Preserve xdataValue(LBound(xdataValue) To UBound(xdataValue) + 1)
xdataType(UBound(xdataType)) = 1000
xdataValue(UBound(xdataValue)) = "Hi, I was added!"
anObj.SetXData xdataType, xdataValue
Set anObj = Nothing
End Sub
© Menhirs NV. All rights reserved. |
