AcCmColor
Class AcadAcCmColor
Member of BricscadDb
The AcCmColor object represents colors. You can use the AcCmColor object to set colors and perform other color-related operations on objects.
This object can hold an RGB value, an ACI number (an integer from 1 to 255), or a named color.
Methods Properties
SetColorBookColor Blue
SetNames BookName
SetRGB ColorIndex
  ColorMethod
  ColorName
  EntityColor
  Green
  Red
