Sub ActiveDocProp_Example() 'This example shows how to return the name of the active document. Dim activeDoc As AcadDocument Set activeDoc = ThisDrawing.Application.ActiveDocument MsgBox "The active document is: " & activeDoc.Name, vbInformation, "ActiveDocument Example " End Sub
© Menhirs NV. All rights reserved. |
