Document property example
Sub Document_Example()
' This example creates a circle in model space and then
' finds the name of the document that the circle resides in.
    Dim circleObj As AcadCircle
    Dim dRadius As Double: dRadius = 5
    Dim cntPnt(0 To 2) As Double
    cntPnt(0) = 2: cntPnt(1) = 2: cntPnt(2) = 0
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(cntPnt, dRadius)
    ThisDrawing.Application.ZoomExtents
    ' Find the document name for the circle
    Dim currDoc As AcadDocument
    Set currDoc = circleObj.Document
    MsgBox "The circle resides in: " & currDoc.Name
End Sub
