Sets or returns the layer of an entity. If you don't specify a layer, the current active layer is used for a new entity. If a layer is specified for an entity, the current active layer is ignored. Each layer has associated properties that can be set and queried through the Layer object.
Syntax
Where:
stringVariable is a variable for storing the layer name.
object is the applicable entity object;
string is the name of a layer to be assigned to an entity.
Examples...
© Menhirs NV. All rights reserved. |
