Sub StyleName_Example() ' This example creates text and adds it to the drawing using the ' AddText method. It then obtains the StyleName property. Dim sText As String: sText = "Test string for StyleName property" Dim insPt(0 To 2) As Double: insPt(0) = 0: insPt(1) = 9 Dim dHeight As Double: dHeight = 5 Dim textObj As AcadText Set textObj = ThisDrawing.ModelSpace.AddText(sText, insPt, dHeight) textObj.Update ThisDrawing.Application.ZoomExtents MsgBox "The StyleName is: " & textObj.StyleName End Sub
