init_dialog
(init_dialog [baseDclFile])
this function instructs the BricsCAD DCL
engine to use the specified file as custom "base.dcl" file or to
use internal defaults only
Arguments |
'baseDclFile' optional; specifies the "base.dcl" file to be used by the DCL engine |
Return |
returns T for success, or NIL to indicate an error |
Example |
Alias |
Remarks |
if the argument 'baseDclFile'
is omitted or nil, then no "base.dcl" file is used for dialog
initialisation, but internal DCL defaults; |
