Redrawing and Regenerating a Drawing
Commands: REGEN, REGENALL, REGENAUTO, REDRAW and REDRAWALL
The Regen command regenerates the current viewport (short for "regenerate").
The Regenall command regenerates all viewports (short for "regenerate all").
The Regenauto command controls when BricsCAD regenerates the drawing automatically.
The Redraw command redraws the current viewport to clean it up.
The Redrawall command redraws all viewports to clean them up.
As a matter of fact the screen display of a drawing is a simplified version of the drawing database. From time to time it is necessary to synchronise the screen display and the drawing database.
The REGENMODE system variable controls whether BricsCAD regenerates the drawing automatically. You can change the status of REGENMODE through the RegenAuto command. If REGENMODE is ON BricsCAD regenerates the display automatically, but in a few cases a forced regeneration of the drawing might be necessary. This is done by the Regen command.
Don't confuse the Regen command with the Redraw command, which simply repaints the screen, without attempting to synchronize the screen display with the drawing database.
Regenerate the current viewport
Do one of the following:
The current viewport is regenerated.
Regenerate all viewports
All viewports are regenerated.
Redraw the current viewport
The current viewport is refreshed.
Redraw all viewports
All viewports are refreshed.
