Match Properties
Command: MATCHPROP
The Matchprop command assigns the
properties of one entity to one or more other entities (short for
"match properties").
To copy properties between entities
- Do one of the following:
- Click the Match (
) tool button on the Standard toolbar.
- Type match in the command bar then press
Enter.
The command bar reads:
Select entity to copy properties from:
- Select the source entity.
Active Settings: 'Color' 'Layer' 'Linetype' 'Linetype Scale'
'Lineweight' 'Thickness' 'Plot Style' 'Dimension' 'Polyline'
'Material' 'Text' 'Shadow Display' 'Hatch' 'Multileader'
Select entities to copy properties to or [Settings]:
- (option) Type S,
then press Enter.
The Match Properties dialog box
displays:
The entity properties you are about to copy display
in the Match Properties dialog.
Adjust the settings, then click the OK button
- Select the target entities.
The command bar reads: Select entities to copy properties to or
[Settings]:
- (option) Repeat step 3 to adjust the
settings, then select more target entities.
- Right click or press Enter to stop.
© Menhirs NV. All rights reserved. |
