Copying Code Examples from the BricsCAD Developer's Reference
Most of the Help topics in the BricsCAD Programmer's Reference contain code examples. You can easily copy these examples into your own code and then further modify them, as desired.
To copy a code example from the Developer's Reference
  1. In the Help window, highlight the code you want to copy.
  2. In the Help window, choose Edit | Copy. (Or, press Ctrl + C.)
  3. Paste the code into your programming environment, using the appropriate command (usually Edit | Paste, or Ctrl + V).
  4. Modify the code, as necessary.
Tell me about...
LISP (LISt Processing)
DCL (Dialog Control Language)
DIESEL (Direct Interactively Evaluated String Expression Language)
COM (Component Object Model)
VBA (Visual Basic for Applications)
BRX (BricsCAD Runtime eXtension)
DTX (Teigha eXtension)
SDS (deprecated)
