Sub AddSolid_Example() ' This example creates a solid to the drawing's model space using the ' AddSolid method. Dim solidObj As AcadSolid Dim pt1(0 To 2) As Double Dim pt2(0 To 2) As Double Dim pt3(0 To 2) As Double Dim pt4(0 To 2) As Double ' Define the solid pt1(0) = 1: pt1(1) = 1: pt1(2) = 0 pt2(0) = 3: pt2(1) = 3: pt2(2) = 0 pt3(0) = 4: pt3(1) = 2: pt3(2) = 0 pt4(0) = 3: pt4(1) = 1: pt4(2) = 0 Set solidObj = ThisDrawing.ModelSpace.AddSolid(pt1, pt2, pt3, pt4) solidObj.Update ThisDrawing.Application.ZoomExtents End Sub
