Sub ArrayRectangular_Example() ' This example adds a circle and applies a rectangular array based on it. Dim pt1(0 To 2) As Double: pt1(0) = 4: pt1(1) = 2: pt1(2) = 0 Dim myCircle As AcadCircle Set myCircle = ThisDrawing.ModelSpace.AddCircle(pt1, 0.5) ' Create a 4x3 array of the circle. myCircle.ArrayRectangular 3, 4, 1, 2, 2, 1 ThisDrawing.Application.ZoomExtents MsgBox "Rectangular array constructed." End Sub
