Gets the size and position of the client area of the window.
Syntax
Where:
object is a BricsCAD Window object;
Left is a Long integer variable defining the left position of the window;
Top is a Long integer variable defining the top position of the window;
Width is a Long integer variable defining the width of the window;
Height is a Long integer variable defining the height of the window.
