Member of BricscadDb.AcadAttribute
Returns the intersection points between given objects.
Syntax
Where:
theObject is the first BricsCAD entity to be intersected;
intersectingObject is the second BricsCAD entity to be intersected;
Option is one of the following constants (AcExtendOption) for intersections:
acExtendBoth = 3 (extends both entities if necessary)
acExtendNone = 0 (does not extend either entity)
acExtendOtherEntity = 2 (extends the second entity)
acExtendThisEntity = 1 (extends the first entity)
Examples...
