Sub Center_Example() ' This example adds an arc to the drawing and returns the area & radius. Dim myArc As AcadArc Dim cenPt(0 To 2) As Double cenPt(0) = 4: cenPt(1) = 2: cenPt(2) = 0 'Add the arc to the .dwg Set myArc = ThisDrawing.ModelSpace.AddArc(cenPt, 3.52, 1, 3) Dim getCenPt As Variant getCenPt = myArc.Center MsgBox "The center point of the arc is" _ & Chr(13) & "x = " & getCenPt(0) _ & Chr(13) & "y = " & getCenPt(1) _ & Chr(13) & "z = " & getCenPt(2) End Sub
