Sub Documents_Example() ' This example obtains a reference to the Documents collection ' and displays information about the loaded documents. Dim thisDocument As AcadDocument Dim allDocuments As AcadDocuments Set allDocuments = ThisDrawing.Application.Documents Dim sBuf As String: sBuf = vbCrLf For Each thisDocument In allDocuments sBuf = sBuf & thisDocument.Name & vbCrLf Next If allDocuments.count > 0 Then MsgBox "The loaded documents are: " & sBuf Else MsgBox "There are no loaded documents!" End If End Sub
© Menhirs NV. All rights reserved. |
