Determines if the object has an extension dictionary associated with it.
Syntax
Where:
BooleanVariable is a variable (True or False) specifying whether the window has an extension dictionary or not.
object is the object or objects this property applies to;it can be one of the following:
All Drawing Objects, AttributeReference, Dictionary, DimStyle, Group, Layer, Linetype, RegisteredApplication, TextStyle, UCS, View, Viewport, XRecord
Examples...
GetExtensionDictionary method example
© Menhirs NV. All rights reserved. |
