Managing VBA projects
BricsCAD™ VBA projects are  stored in separate .DVB file.
Macros contained within the DVB file or in the common project file are not directly compatible with stand-alone Visual Basic projects (VBP files); however, forms, modules, and classes can be exchanged between dissimilar projects using the IMPORT and EXPORT VBA commands in the VBA IDE.
Tell me about...
VBA (Visual Basic for Applications)
Overview of automation
Starting VBA
Inserting UserForms
Adding controls to a UserForm
Creating code
Using modules
Running a VBA program
