toggle
A DCL toggle is a child tile. A toggle displays a check mark that
can be selected or selected by mouse or keyboard.
related attributes
- These attributes are predefined for every child tile and
consequently for a toggle as well:
- These attributes are predefined for every tile and consequently
- key
- value
- The value of a toggle refers to its
selected state. If a toggle is selected, its value is "1". If a
toggle is not selected, its value is "0".
- tooltip
- label
- Use the label attribute to set the
text contents of a toggle.
- fixed_height
- fixed_width
- alignment
- width
- bcad_width
- height
- bcad_height
- is_enabled
callbacks
When a toggle is being changed by
clicking it or by using the keyboard, a callback with reason
"CBR_SELECT" will be triggered.
© Menhirs NV. All rights reserved. |
