DdSTrack
Sets the properties for snap tracking, through the Settings dialog box (short for "dynamic dialog snap tracking").
command bar:  ddstrack
transparent:  'ddstrack
alias:  settings
status bar:  STRACK
: ddstrack
Displays the Snap Tracking section of the Settings dialog box:
Change settings, and then click X.
AutoSnap
Specifies the look and action of AutoSnap:
  • AutoSnap Marker - toggles the display of the AutoSnap marker, which indicates the type of entity snap; default = ON.
  • AutoSnap Tooltips -  toggles the display of tooltips adjacent to the entity snap location; default = ON.
  • AutoSnap Magnet - toggles whether AutoSnap jumps to the nearest entity snap geometry; default = ON.
  • Polar Tracking - toggles polar tracking, where BricsCAD shows polar angles; default = ON.
  • Entity Snap Tracking - toggles entity snap tracking; default = ON.
  • Tooltips for Polar Tracking and Entity Snap Tracking - toggles the display of tooltips; default = on
  • Tracking line from LASTPOINT - toggle the display of a tracking line from the most recently specified point; default = ON.
Polar Angle
Specifies the default polar snap increment; default = 90.
Polar Add Angles
Specifies additional user-defined angles for polar snap.
Polar Mode
Specifies how polar mode is handled. The value is stored as the sum of the values of the selected options:
  • 1 - Measure polar angles from selected entities (relative); default.
  • 2 - Use polar tracking settings in entity snap tracking.
  • 4 - Use additional polar tracking angles.
  • 8 - Press the Shift-key to acquire entity snap tracking points.
Track Path
Determines how the tracking path is displayed. The options are:
  • Display full-screen entity snap tracking path.
  • Display entity snap path only between the alignment path and the From point to the cursor location; default.
  • Do not display polar tracking path.
  • Do not display polar or entity snap tracking paths.
-OSnap - toggles entity snap modes at the command line.
OSnap - sets entity snaps through the Settings dialog box.
