Creates and modifies named groups of entities.
command bar: group
menu bar: Tools | Group
toolbar: Tools | ![]()
: group
Create or edit a named group, and then click OK.
Toggles the display of unnamed groups:
Reports the name(s) of groups when you select entities in the drawing. Temporarily removes the dialog box, and then prompts: Select entities - choose one or more entities. Select entities - choose more entities, or press Enter to continue. Displays the Group Member List dialog box:
Click OK to close this dialog box and to return to the Entity Grouping dialog box. |
Highlights entities that belong to the selected group.
Removes group status from selected entities. Select groups in the Group Names list, and then click this button. The names disappear from the list. |
Create Group |
Specifies the names of groups. |
Specifies an optional description of the group. |
Toggles group naming:
Unnamed groups are assigned the prefix *A following by an incremented number, such as *A2. |
Toggles the selectability of a group if the Group Selection option of the PICKSTYLE system variable is set (PICKSTYLE = 1 or 3.
Dismisses the dialog box temporarily, and then prompts you at the command bar: Select entities - choose one or more entities. Select entities - choose more entities, or press Enter to return to the dialog box. Back in the dialog box, the selected entities become part of the group. |
Change Group |
Adds entities to the selected group; prompts you at the command bar: Select entities - choose one or more entities. Select entities - choose more entities, or press Enter to return to the dialog box. |
Removes entities from the selected group; prompts you at the command bar: Select entities - choose one or more entities. Select entities - choose more entities, or press Enter to return to the dialog box. |
Changes the order of entities in groups; displays the Order Group dialog box. |
Order Group |
Group Name |
Lists the names of named and unnamed groups. |
Remove From Position |
Specifies the position number of the entity, which is to be renumbered. |
Enter New Position Number for the Entity |
Specifies the new position number for the entity. |
Number of Entities |
Specifies the range of entities to reorder. |
Re-Order |
Applies the re-ordering dictated by the previous three fields. |
Highlight |
Highlights entities in the group; dismisses the Order Group dialog box, and then displays the following one:
Next - highlights the next entity of the group. Previous - highlights the previous entity. OK - returns to the Order Group dialog box. |
Reverses the order of entities in the group. |
Grips Editing
Groups can be edited directly through grips in two ways:
Selectable - select one entity in the group, and all entities are selected (show highlights and grips).
Not Selectable - select one entity and only that entity is selected, such as the ellipse shown below.
Procedures
To change the order of entities
-Group - creates and modifies named groups of entities, at the command line.
Block - groups entities into a block (symbol), through a dialog box
-Block - groups entities into a block (symbol), at the command line.
