Links entities with files and Web pages with a dialog box.
command bar: hyperlink
shortcut: Ctrl+K
: hyperlink
Select entities: (Choose one or more entities.)
Entities in set: 1
Select entities: (Choose one or more entities, or press Enter to continue command.)
Change hyperlink options, and then click OK.
Each entity can contain just one hyperlink.
Link to file or URL |
Specifies the hyperlink; can be the path and name of a file, networked file, or location on the Internet. Locations on the Internet can include Web pages (http://), FTP sites (ftp://), and so on. Examples of hyperlink syntax are as follows: File - C:\foldername\filename.ext Networked file - \\networkname\c\foldername\filename.ext URL - https://www.bricsys.com or www.bricsys.com |
Displays the Select File dialog box; choose a file, and then click Open. Any type of file can be linked to. |
Use relative path |
Uses the path specified by Hyperlink Base. Hyperlink base + relative path = full path or URL. |
Remove link |
Removes the link from the entity. |
Hyperlink base |
Specifies the path to relative hyperlinks. |
Named location in file |
Specifies a bookmark name. The # character is used to specify locations (bookmarks) within files or Web pages, such as www.bricscad.sys#bookmark. |
Hyperlink description |
Describes the URL or file; this description is displayed in a tooltip when the cursor is paused over the entity; see HyperlinkOptions command. |
-Hyperlink - attaches hyperlinks through the command bar.
HyperlinkOptions - sets options for hyperlinks.
Settings - sets options for hyperlinks in the Files section of the Settings dialog box.
Browser and Url - open the default Web browser.
OnWeb - opens the Bricsys home page in your computer's default Web browser.
Mail - attaches the current drawing to a message in the default email client.
