Pro, Platinum
Pro, Platinum
Pro, Platinum
Displays the Drawing Explorer - Lights dialog window.
command bar: lightlist
alias: LL
menu bar: Tools | Drawing Explorer | Lights...
toolbar: Lights | ![]()
: lightlist
Starts the LIGHT command. |
Deletes the selected lights. |
Closes the Drawing Explorer - Lights dialog box. Selects the light's glyph in the drawing; the light's properties display in the Properties Bar. |
Rename |
Edit the name of the light. |
Select all |
Selects all lights in the light list. Choose Select in drawing to select the glyphs of all lights in the drawing. |
Indicates the light is currently switched on. Click to turn the light off. |
Indicates the light is currently switched off. Click to turn the light on. |
Sun |
Sets the properties of the sunlight. See the SunProperties command. |
Geographic Location |
Launches the GeographicLocation command. |
Light: Creates a new light.
Render: Calculates a photorealistic image of the 3D model.
Sunproperties: Displays the Sun Properties of the Active Viewport editor in the Drawing Explorer - Lights dialog.
GeographicLocation: Sets the geographic location of the drawing.
