Platinum
Platinum
Platinum
Allows to list and edit the parameters of inserted components.
command bar: -bmparameters
: -bmparameters
Select component instances: (Select a component.)
Entities in set 1
Select component instances: (Select more components or press Enter.)
Enter an option to change parameter expression [Edit/Delete/?] <?>: (Press Enter to list the parameters of the selected components in the Prompt History window.)
Edit |
Allows to edit the value of a parameter. Prompts you: Enter parameter name: Type the name of a parameter. Enter expression: Type a value in the command bar. |
Delete |
Allows to reset a previously edited parameter to its default value. Prompts you: Enter parameter name: Type the name of a parameter. |
Lists the parameters of the selected components in the Prompt History window. Press the F2 function key to display the Prompt History window. |
-Parameters - manages dimensional constraint parameters in the current drawing.
