Toggles the display of the status bar (short for "status bar").
command bar: statbar
transparent: 'statbar
shortcut: Shift + F3
menu bar: View | Status Bar
: statbar
WNDLSTAT is currently on: OFF/Toggle/<On>: (Enter an option.)
The status bar provides useful information and controls:
Status field:
displays a tooltip when hovering over a tool button
displays command prompts when the command bar is closed
double click the status field to toggle the command bar on/off
Coordinates field
Drawing properties
Drawing aids
Status bar option button.
Displays a list: Click an option to toggle the corresponding field
on/off.
The only reason to turn off the status bar is to gain a bit more drawing area.
Procedures
CommandLine - shows the command line.
CommandLineHide - hides the command line.
GraphScr - brings the graphics window to the foreground.
Scrollbar - toggles the display of the scroll bars.
TextScr - brings the text window to the foreground.
Toolbar and -Toolbar - toggle the display of toolbars.
