AddItems method example
Sub AddItems_Example()
    Dim ssetObj As AcadSelectionSet
    Dim i As Integer
    Dim lineObj As AcadLine
    Dim startPoint(0 To 2) As Double
    Dim endPoint(0 To 2) As Double
    Dim circObj As AcadCircle
    Dim centerPt(0 To 2) As Double
    Dim dRadius As Double
    Dim ssetName
    ssetName = InputBox("Type a name for the selection set:")
    Set ssetObj = ThisDrawing.SelectionSets.Add(ssetName)
    startPoint(0) = 3: startPoint(1) = 1: startPoint(2) = 0
    endPoint(0) = 5: endPoint(1) = 5: endPoint(2) = 0
    Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
    centerPt(0) = 3: centerPt(1) = 1: centerPt(2) = 0
    dRadius = 5
    Set circObj = ThisDrawing.ModelSpace.AddCircle(centerPt, dRadius)
    ReDim ssobjs(0 To ThisDrawing.ModelSpace.Count - 1) As AcadEntity
    For i = 0 To ThisDrawing.ModelSpace.Count - 1
        Set ssobjs(i) = ThisDrawing.ModelSpace.Item(i)
    Next i
    ssetObj.AddItems ssobjs
    MsgBox "No. of items in sel. set = " & ssetObj.Count
    ssetObj.Clear
    MsgBox "No. of items in sel. set (after clearing) = " & ssetObj.Count
End Sub
| ©  Menhirs NV. All rights reserved. |
