AddPolyfaceMesh method example
Sub AddPolyfaceMesh_Example()
Dim faceObj As AcadPolyfaceMesh
Dim vertexList(0 To 29) As Double
vertexList(0) = 0: vertexList(1) = 0: vertexList(2) = 0
vertexList(3) = -2: vertexList(4) = 2: vertexList(5) = 0
vertexList(6) = 0: vertexList(7) = 4: vertexList(8) = 0
vertexList(9) = 4: vertexList(10) = 4: vertexList(11) = 0
vertexList(12) = 6: vertexList(13) = 2: vertexList(14) = 0
vertexList(15) = 0: vertexList(16) = 0: vertexList(17) = 1
vertexList(18) = -2: vertexList(19) = 2: vertexList(20) = 1
vertexList(21) = 0: vertexList(22) = 4: vertexList(23) = 1
vertexList(24) = 4: vertexList(25) = 4: vertexList(26) = 1
vertexList(27) = 6: vertexList(28) = 2: vertexList(29) = 1
Dim faceList(0 To 15) As Integer
faceList(0) = 1
faceList(1) = 2
faceList(2) = 7
faceList(3) = 6
faceList(4) = 2
faceList(5) = 3
faceList(6) = 8
faceList(7) = 7
faceList(8) = 3
faceList(9) = 4
faceList(10) = 9
faceList(11) = 8
faceList(12) = 4
faceList(13) = 5
faceList(14) = 10
faceList(15) = 9
Set faceObj = ThisDrawing.ModelSpace.AddPolyfaceMesh(vertexList, faceList)
faceObj.Update
ThisDrawing.Application.ZoomExtents
End Sub
© Menhirs NV. All rights reserved. |
