AddRaster method example
Sub AddRaster_Example()
    Dim insPoint(0 To 2) As Double
    Dim scalefactor As Double
    Dim rotationAngle As Double
    Dim imageName As String
    Dim rasterObj As AcadRasterImage
    imageName = "C:test.jpg"
    insPoint(0) = 4: insPoint(1) = 2: insPoint(2) = 0
    scalefactor = 1
    rotationAngle = 0
    Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insPoint, scalefactor, rotationAngle)
    rasterObj.Update
    ThisDrawing.Application.ZoomExtents
    MsgBox "The property .ImageFile is: " & rasterObj.ImageFile
    MsgBox "The property .ImageHeight (in drawing units) is: " & rasterObj.ImageHeight & _
    Chr(13) & "The property .ImageWidth (in drawing units) is: " & rasterObj.ImageWidth
    MsgBox "The property .Height (in pixels) is: " & rasterObj.height
    MsgBox "The property .Width (in pixels) is: " & rasterObj.width
    MsgBox "The property .ImageVisibility is: " & rasterObj.ImageVisibility
End Sub
| ©  Menhirs NV. All rights reserved. |
