Sub AddTextExample() ' This example creates Text and adds it to the drawing using the ' AddText method. Dim sBuf As String Dim oText As AcadText Dim insPt(0 To 2) As Double insPt(0) = 0: insPt(1) = 9 Dim dHeight As Double dHeight = 1 sBuf = "Test string for the AddText method" ' Add the text Object Set oText = ThisDrawing.ModelSpace.AddText(sBuf, insPt, dHeight) oText.Update ThisDrawing.Application.ZoomExtents End Sub
