Class AcadPreferencesPdfOutput
Member of BricscadApp
Use following to obtain a reference to the PreferencesPdfOutput object:
Dim pdfPref As AcadPreferencesPdfOutput
Set pdfPref = ThisDrawing.Application.Preferences.Output.Pdf
The PreferencesPdfOutput object contains PdfOutput settings (stored in registry). The object contains following properties:
| Properties |
| Application |
| EmbeddedTtf |
| LayersSetting |
| LayoutsToExport |
| PaperHeight |
| PaperSizeOverride |
| PaperWidth |
| ShxTextAsGeometry |
| SimpleGeomOptimization |
| TtfTextAsGeometry |
| UsePlotStyles |
| ZoomToExtents |
