Sub DisplayScrollBars_Example() ' This example toggles the DisplayScrollBars property Dim myPrefs As AcadPreferences Set myPrefs = ThisDrawing.Application.preferences Dim scrollBarStatus As Boolean scrollBarStatus = myPrefs.Display.DisplayScrollBars MsgBox "The DisplayScrollBars property is: " & scrollBarStatus 'Toggle the visibility of the scroll bars. myPrefs.Display.DisplayScrollBars = Not (scrollBarStatus) MsgBox "The DisplayScrollBars property is now: " & myPrefs.Display.DisplayScrollBars End Sub
