Rotation property example
Sub Rotation_Example()
Dim sText As String: sText = "Test string for Rotation property"
Dim insPt(0 To 2) As Double: insPt(0) = 0: insPt(1) = 9
Dim dHeight As Double: dHeight = 5
Dim textObj As AcadText
Set textObj = ThisDrawing.ModelSpace.AddText(sText, insPt, dHeight)
textObj.Update
ThisDrawing.Application.ZoomExtents
MsgBox "The ObliqueAngle is " & textObj.Rotation
textObj.Rotation = 0.785
textObj.Update
MsgBox "The Rotation is set to " & textObj.Rotation
End Sub
© Menhirs NV. All rights reserved. |
