Sub TextString_Example() ' This example creates text and adds it to the drawing using the ' AddText method. It then returns the TextString in a message box. Dim sText As String: sText = "Test string for the AddText method" sText = InputBox("Type some text here:") Dim insPt(0 To 2) As Double: insPt(0) = 0: insPt(1) = 9: insPt(2) = 0: Dim dHeight As Double: dHeight = 5 ' Add the Text object Dim oText As AcadText Set oText = ThisDrawing.ModelSpace.AddText(sText, insPt, height) ThisDrawing.Application.ZoomExtents MsgBox "The text you entered is: " & oText.TextString End Sub
