Sub Thickness_Example() ' This example adds an arc to the drawing. It then obtains ' the Thickness property and prompts the user to supply a new thickness. Dim myArc As AcadArc Dim cenPt(0 To 2) As Double: cenPt(0) = 4: cenPt(1) = 2 Set myArc = ThisDrawing.ModelSpace.AddArc(cenPt, 3, 1, 3) Dim dThickness As Double dThickness = myArc.Thickness MsgBox "Arc's thickness = " & dThickness dThickness = InputBox("Enter new thickness for arc:") myArc.Thickness = dThickness MsgBox "Arc's thickness = " & dThickness End Sub
