BricsCAD™ VBA projects are stored in separate .DVB file.
Macros contained within the DVB file or in the common project file are not directly compatible with stand-alone Visual Basic projects (VBP files); however, forms, modules, and classes can be exchanged between dissimilar projects using the IMPORT and EXPORT VBA commands in the VBA IDE.
Tell me about...
VBA (Visual Basic for Applications)
