Panning
Commands: PAN and
RTPAN
The Pan command moves the drawing
in any direction: horizontally, vertically, or diagonally. The
magnification of the drawing remains the same, as does its
orientation in space. The only change is the portion of the drawing
being displayed. The cursor changes to a hand (
) when a Pan tool is
active.
The Rtpan command pans the drawing
in real-time.
See also: View manipulation
using the mouse.
Using the pan command
- To launch the Pan command do one of the
following:
- Click the Pan
tool button (
) on the View
toolbar (Zoom flyout).
- Choose Zoom >
Pan in the View
menu.
- Type p or
pan in the command bar, then press
Enter.
You are prompted:
Left/Right/Up/Down/PGLeft/PGRight/PGUp/PGDown/<Pan base
point>:
A prompt menu opens:
- Specify the Pan base
point.
You are prompted: Pan displacement point:
- Specify the Pan
displacement point.
The display shifts over the specified distance and in the specified
direction.
Using real time panning
- To launch the Real-time Pan command do one of the
following:
- Click the Real-Time
Pan tool button (
) on the Real-Time Motion toolbar
- Choose Real-Time
Motion > Real-Time Pan in
the View menu.
- Type rtpan in
the command bar, then press Enter.
You are prompted: >>ENTER, Right click or Esc
to complete...
- Press and hold the left mouse button to pan the
view.
- To abort the Real-Time
Pan command, do one of the following:
- Right click.
- On the keyboard, press Enter, space bar or
Esc.
© Menhirs NV. All rights reserved. |
