Zooming
Command: ZOOM and RTZOOM
The Zoom command visually changes
the size of the drawing within the current viewport.
The Rtzoom command zooms the
drawing in real-time.
You can change the magnification of your drawing at any time by
zooming. The cursor changes to a magnifying glass (
) when a Zoom tool is active.
Zoom out to reduce the magnification so you can see more of the
drawing, or zoom in to increase the magnification so you can see a
portion of the drawing in greater detail. Changing the
magnification of the drawing affects only the way the drawing is
displayed; it has no effect on the dimensions of the entities in
your drawing.
See also: View manipulation
using the mouse.
Using the zoom command
- Do one of the following:
- Choose zoom in
the View menu.
- Type zoom in
the command bar.
- Type Z in the
command bar.
You are prompted:
In/Out/All/Center/Dynamic/Extents/Left/Previous/Right/Window/<Scale
(nX/nXP)>:
A prompt menu opens:
- Type the zoom factor, followed by
X. E.g. type 2x to magnify the display 2 times; typing
0.5x changes the display to half its
original size.
- In paper space viewports, type
the zoom factor followed by XP to
define the zoom factor relative to the viewport, thus defining the
scale of the viewport content.
- Pick two corners of a box on the existing
view in order to enlarge that area to fill the display.
Real-time zooming
- Click the Real-Time
Zoom tool button (
) in the View toolbar.
- Type rtzoom in
the command bar, then press Enter.
You are prompted: >>ENTER, Right click or Esc
to complete...
- Press and hold the left mouse button.
Move the mouse forward to zoom in.
Move the mouse backward to zoom out.
- To abort the Real-Time
Zoom command, do one of the following:
- Right click.
- On the keyboard, press Enter, space bar or
Esc.
Dynamic zooming
- Choose zoom in
the View menu.
- Type zoom in
the command bar.
- Type Z in the
command bar.
A prompt menu displays.
You are prompted:
(nX/nXP)>:
- Choose Dynamic
in the prompt menu.
- Type D, then
press Enter.
A view extents or view limits (if larger) is
executed first.
A view box displays. The original size of the view
box matches the size of the previous view.
A dashed rectangle indicates the area of the
previous view.
- (option) To resize the view box:
- Click to switch to resize mode. A right
pointing arrow indicates you are in resize mode.
- Move the mouse to adjust the size.
- Click to leave resize mode.
- Move the view box to the area you want to enlarge,
then right click.
The drawing is zoomed in on the selected area.
- Repeat steps 1 through 4 to zoom in on another
part of the drawing.
© Menhirs NV. All rights reserved. |
