Command: LAYOUT
In BricsCAD, you can create up to 255 layouts in a single drawing. Each layout represents a sheet of paper. For each layout you can specify the print area, print scale, lineweight scale, pen mappings, and add viewports, dimensions, a title block, and other geometry specific to the layout. The entities you add to a layout in paper space do not appear in model space.
Each layout requires at least one layout viewport. If the CREATEVIEWPORTS system variable is ON a viewport is added automatically in a new layout. If this variable is OFF, newly created viewports are empty. To add new layouts you can either define them yourself or your can import layouts from another drawing: template file (.dwt), drawing file (.dwg) or drawing interchange file (.dxf).
Viewports can display all or part of the drawing’s model space entities.
The CACHELAYOUT system variable controls whether the content of layouts is cached. The extra memory required for caching is made up for by improvements to the memory requirements for displaying entities, the net result being that the memory needed to display drawings has been reduced. As a result of this switching between layouts is up to 10 times faster now.
The Ctrl-PgUp or Ctrl-PgDn keyboard shortcuts allow to open the next or previous layout.
You are prompted: Enter a layout name. <Layout1>:
The new layout tab is added.
Drag the layout tab to the desired position
or
Do one of the following:
Choose Drawing Explorer > Page Setups... in the Tools menu.
Choose Page Setup... in the File menu.
The Drawing Explorer - Page Setups dialog displays.
Select the layouts you want to delete.
To select a series of layouts: select the first layout, then press
and hold the Shift key and select the last layout.
Press and hold the Ctrl-key to add/remove layouts.
Click the Delete tool
button (
) in the toolbar on the
toolbar.
An alert box displays:
Press the Yes button on the Delete Layouts alert box.
