Lights
Commands: DISTANTLIGHT, GEOGRAPHICLOCATION,  LIGHT, LIGHTLIST, POINTLIGHT, SPOTLIGHT, SUNPROPERTIES, WEBLIGHT
Lighting is the key to make the viewer believe to look at a realistic scene.
Lighting glossary
System variables
LIGHTINGUNITS (Lighting units):
DEFAULTLIGHTING (Default lighting): A distant light that follows the view direction. This setting can be different per viewport.
LINEARCONTRAST (Linear contrast): Specifies the ambient light intensity. Values between -10 and 10 are accepted. A value of -10 results in maximum ambient light. A value of 10 results in no ambient light.
LINEARBRIGHTNESS (Linear brightness): Specifies a scaling factor for the light intensity. Values between -10 and 10 are accepted. The default value is 0 (no scaling). Negative values decrease the light intensity, positive values increase the light intensity. This setting can be different per viewport.
General properties
The general properties are common to all lights:
Photometric light properties
LIGHTINGUNITS = 1 (American units) or 2 (International units).
color temperatures
lamp color list
Geometry properties
Attenuation properties
In the real world, an object appears darker if it is farther away from the light source. The attenuation properties define how the light diminishes over distance.  Attenuation does not apply to photometric lights.
An alternative method to control the distance a light shines is the use of limits, which define the points from where a light starts to shine and where it stops. Using limits decreases the time needed to calculate the illumination of a scene.
Attenuation properties apply to spot lights and point lights.
No attenuation
Inverse linear attenuation
Inverse square attenuation
The Attenuation properties apply to generic lights only (LIGHTINGUNITS = 0).
Inverse square attenuation is applied automatically for photometric lights ( LIGHTINGUNITS = 1  or 2).
Rendered shadow details
Spotlight hotspot and falloff properties
When a surface is illuminated by a spotlight, there is an area of maximum illumination (hotspot = 1) that is surrounded by an area of lesser intensity (falloff  = 2).
Hotspot angle = 55, Falloff angle = 60
Hotspot angle = 30, Falloff angle = 60
The difference between the hotspot angle and the falloff angle defines the area of lesser light intensity.
If the falloff angle and the hotspot angle are almost equal  the edge of light cone is rather sharp (left).
The greater the difference between both angles, the softer the edge of the light cone (right).
To open the light list in the Drawing Explorer
Do one of the following:
Icon
Tool name
New light
Closes the Drawing Explorer - Lights dialog, then guides you to the creation of a new light in the drawing.
Delete light
Deletes the selected light.
Select in drawing
Closes the Drawing Explorer - Lights dialog and selects the light's glyph in the drawing.
The properties of the light display in the Properties Bar.
Light ON
Click to switch light off.
Light OFF
Click to switch light on.
To define a light
  1. Do one of the following:
  2. Type light in the command bar, then press Enter.
You are prompted: Enter light type [Point/Spot/Web/Distant] <Point>:
A prompt menu displays:
Choose a light type in the prompt menu.
  1. Click the tool button of the light type you want to create on the Lights toolbar:
You are prompted: Specify target position <0,0,-10>:
You are prompted: Enter an option to change: Name/Intensity factor/Status/Photometry/Hotspot/Falloff/shadoW/Attenuation/filterColor/<eXit>:
You are prompted: Enter light name <Spotlight1>:
You are prompted to define the selected property in the command bar.
  1. Do one of the following to conclude the creation of the light:
  2. Choose Exit in the prompt menu.
  3. Press Enter.
NOTE
It is not possible to define a web light if the LIGHTINGUNITS system variable is zero (No lighting units).
To edit a light
  1. Select the light in the drawing.
    If the Properties bar is not open yet, double click the light.
The properties of the selected light display in the Properties Bar:
Generic light properties
  1. To edit a property:
  2. Expand the settings group if needed.
  3. Select the property
  4. Edit the selected property.
To define the sun properties
  2. Click the Sun Properties... tool button () on the Render toolbar.
  3. Type sunproperties or sun in the command bar, then press Enter.
The Drawing Explorer - Lights dialog displays, showing the sun properties in the Editor pane.
NOTE
When LIGHTINGUNITS = 1 or 2, the Color property of the sun cannot be edited.
To define the geographic location
  2. Click the Geographic location... tool button () on the Render toolbar.
  3. Click the Geographic location... tool button () on Editor pane of the Drawing Explorer - Lights dialog.
  4. Type geographiclocation or geo in the command bar, then press Enter.
The Geographic Location dialog displays:
  1. (option) Check the Store geographic location information in drawing option.
  2. (option) Check the Use Map Grid coordinate system option.
  3. Do one of the following:
  4. Type the latitude and longitude of the location in the Latitude and Longitude fields and select the appropriate hemisphere for each setting.
  5. Click the Choose location... button, then select a city and timezone and click the OK button.
  1. (option) If you did not select a time zone in the previous step, choose a time zone in the Time Zones list.
  2. (option) Specify the Coordinates of the corresponding location in the drawing.
  3. Define the direction of the north.
  4. Click the OK button.
