VLX NameSpace Compatibility
Since DEScoder.exe v2.7 :
The "VLX NameSpace" feature to isolate Lisp code running in an own "NameSpace" (prevents clashes of same-named functions, between different Lisp files).is available since DEScoder v2.7, and supported since BricsCAD V18.2.
But the internal DES data format and options storage has been made backward + forward compatible, to provide best level of compatibility possible.
The following table shows the relations between DEScoder versions and BricsCAD versions :
Lisp files encrypted by
works in BricsCAD V11 - V18.1
works in BricsCAD >= V18.2
DEScoder <= V2.6
no NameSpace support
Yes
Yes
DEScoder >= V2.7
NameSpace feature disabled
NameSpace feature enabled
Yes
Partially (no NameSpaces available !)
Yes
Yes
©  Bricsys NV. All rights reserved.
