dos_popupmenu
(dos_popupmenu  menuitems  [itemmodes])
Shows a popup menu at actual cursor (mouse) position on screen. The user can dismiss the menu by ESCAPE key or clicking anywhere outside the menu.
menuitems : list of strings, specifying the menu item labels; an empty string "" creates a separator item
itemmodes : optional argument; list of integers specifying the item state for each menu item
0 enabled
1 disabled
2 checked, enabled
3 checked, disabled
each menu item defaults to state 0 (enabled, not checked)
Return : the index of selected item, or NIL on error or escaped menu;
Note : separator items do not count for the item indices !
Examples :
(setq items '("Select" "" "First Entity" "Second Entity"))
(setq modes '(0 0 3 0))
(dos_popupmenu items modes)
(dos_popupmenu items)
©  Bricsys NV. All rights reserved.
