Erase method example
Sub Erase_Example()
    Dim pt1(0 To 2) As Double
    Dim pt2(0 To 2) As Double
    pt1(0) = 3: pt1(1) = 3: pt1(2) = 0
    pt2(0) = 1: pt2(1) = 3: pt2(2) = 0
    Dim rayObj As AcadRay
    Set rayObj = ThisDrawing.ModelSpace.AddRay(pt1, pt2)
    Dim points(0 To 5) As Double
    points(0) = 3: points(1) = 7
    points(2) = 9: points(3) = 2
    points(4) = 3: points(5) = 5
    Dim plineObj As AcadLWPolyline
    Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
    plineObj.Closed = True
    pt1(0) = 0: pt1(1) = 0: pt1(2) = 0
    pt2(0) = 2: pt2(1) = 2: pt2(2) = 0
    Dim lineObj As AcadLine
    Set lineObj = ThisDrawing.ModelSpace.AddLine(pt1, pt2)
    pt1(0) = 20: pt1(1) = 30: pt1(2) = 0
    Dim radius As Double: radius = 3
    Dim circObj As AcadCircle
    Set circObj = ThisDrawing.ModelSpace.AddCircle(pt1, radius)
    Dim majAxis(0 To 2) As Double
    Dim center(0 To 2) As Double
    Dim radRatio As Double
    center(0) = 5#: center(1) = 5#: center(2) = 0#
    majAxis(0) = 10: majAxis(1) = 20#: majAxis(2) = 0#
    radRatio = 0.3
    Dim ellObj As AcadEllipse
    Set ellObj = ThisDrawing.ModelSpace.AddEllipse(center, majAxis, radRatio)
    ZoomAll
    Dim oSS As AcadSelectionSet
    Set oSS = ThisDrawing.ActiveSelectionSet
    oSS.Clear
    ReDim arrayOfObjects(0 To ThisDrawing.ModelSpace.Count - 1) As AcadEntity
    Dim i As Integer
    For i = 0 To ThisDrawing.ModelSpace.Count - 1
        Set arrayOfObjects(i) = ThisDrawing.ModelSpace.Item(i)
    Next
    oSS.AddItems arrayOfObjects
    MsgBox getContent(oSS)
    oSS.Erase
    Set oSS = Nothing
    ThisDrawing.Application.ZoomExtents
End Sub
Private Function getContent(inSelectionSet As AcadSelectionSet) As String
    Dim sBuf As String:    sBuf = vbNullString
    Dim i As Integer
    If inSelectionSet.Count = 0 Then
            sBuf = "The selection set is empty"
        Else
            sBuf = "The selection set contains:"
            For i = 0 To inSelectionSet.Count - 1
                sBuf = sBuf & vbCrLf & inSelectionSet.Item(i).ObjectName
            Next
    End If
    getContent = sBuf
End Function
| ©  Bricsys NV. All rights reserved. |
