GetBulge method example
Sub GetBulge_Example()
    Dim myLWP As AcadLWPolyline
    Dim myPoints(0 To 5) As Double
    myPoints(0) = 0: myPoints(1) = 0
    myPoints(2) = 3: myPoints(3) = 0
    myPoints(4) = 3: myPoints(5) = 4
    Set myLWP = ThisDrawing.ModelSpace.AddLightWeightPolyline(myPoints)
    myLWP.Closed = True
    myLWP.Update
    ThisDrawing.Application.ZoomExtents
    Dim currentBulge As Double
    currentBulge = myLWP.GetBulge(2)
    MsgBox "The bulge for the second segment is " & currentBulge, , "Get/SetBulge example "
    myLWP.SetBulge 2, 1.3
    myLWP.Update
    MsgBox "The bulge for the second segment is now " & myLWP.GetBulge(2), , "Get/SetBulge Example "
End Sub
| ©  Bricsys NV. All rights reserved. |
