GetUCSMatrix method example
Sub GetUCSMatrix_Example()
    Dim ucsObj As AcadUCS
    Dim origin(0 To 2) As Double
    Dim xAxisPoint(0 To 2) As Double
    Dim yAxisPoint(0 To 2) As Double
    origin(0) = 2: origin(1) = 2: origin(2) = 0
    xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) = 0
    yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) = 0
    Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
    ThisDrawing.ActiveUCS = ucsObj
    ThisDrawing.ActiveViewport.UCSIconOn = True
    ThisDrawing.ActiveViewport.UCSIconAtOrigin = True
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 1: center(1) = 1: center(2) = 0
    radius = 0.5
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
    ZoomAll
    Dim TransMatrix As Variant
    TransMatrix = ucsObj.GetUCSMatrix()
    MsgBox "Transform the circle.", , "GetUCSMatrix Example"
    circleObj.TransformBy (TransMatrix)
    circleObj.Update
    MsgBox "The circle is transformed.", , "GetUCSMatrix Example"
End Sub
| ©  Bricsys NV. All rights reserved. |
