ContourLinesPerSurface property example
Sub ContourLinesPerSurface_Example()
    Dim currContourLinesPerSurface As Integer
    Dim newContourLinesPerSurface As Integer
    currContourLinesPerSurface = ThisDrawing.Preferences.ContourLinesPerSurface
    MsgBox "The current value for ContourLinesPerSurface is " & currContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
    newContourLinesPerSurface = 2001
    ThisDrawing.Preferences.ContourLinesPerSurface = newContourLinesPerSurface
    MsgBox "The new value for ContourLinesPerSurface is " & newContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
    ThisDrawing.Preferences.ContourLinesPerSurface = currContourLinesPerSurface
    MsgBox "The ContourLinesPerSurface value is reset to " & currContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
End Sub
| ©  Bricsys NV. All rights reserved. |
