HasExtensionDictionary property example
Sub GetExtensionDictionary_Example()
    Dim EDictionary As AcadDictionary
    Dim circleObj As AcadCircle
    Dim centerPoint(0 To 2) As Double
    Dim radius As Double
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius = 5#
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    ThisDrawing.Application.ZoomAll
    MsgBox "Circle object Extension Dictionary state before: " & circleObj.HasExtensionDictionary
    Set EDictionary = circleObj.GetExtensionDictionary
    MsgBox "Circle object Extension Dictionary state after: " & circleObj.HasExtensionDictionary
End Sub
| ©  Bricsys NV. All rights reserved. |
